Is there a square texture projection in the Houdini?
6793 7 0- dddmod___
- 76 posts
How to get a square texture projection in Houdini? The uvproject has different variants, even there is a projection for the torus https://monosnap.com/file/0FQdRRk6k1FSvOLqC1JLYxo3Ja0iw5 [monosnap.com] but there is no usual square texture projection :-) I would be grateful if someone share with me their experience
- Siavash Tehrani
- 729 posts
- dddmod___
- 76 posts
DaJuiceI mean this thing https://monosnap.com/file/byhr40mAKq3FgcN69ZTEuGix4ij1hm [monosnap.com] it's the most used projection in simple texturing. Flat projection is useless.
Orthographic is the same as “planar” projection in some other apps, if that's what you mean by square. If you want a cubic projection I believe you will want the UV Unwrap SOP rather than UV Project.
- Siavash Tehrani
- 729 posts
- CYTE
- 708 posts
- israelfornes
- 1 posts
- jordanhalsey
- 12 posts
- CYTE
- 708 posts
