Asset creation: can't change naming
   1739   3   1
Hi!
I'm new to asset creation and I wanted to have a switch appear as a toggle in the parameter interface. It works but I can't change the name from “select input” to “color check”. Is something locked?
-Olivier
Hi Olivier,
That looks like its bugged. Try deleting the toggle parameter and then recreate it. Also, try quit Houdini and relaunch.
Richard.
Use the Type Properties dialog to edit an hda definition's parameter dialog. The edit parameter interface is for editing a node's parameters and does not allow changing parameters that are part of the definition.(you can only rename ‘spare’ parameters, ones that are added to the node instance)
http://www.sidefx.com/docs/houdini/ref/windows/optype.html [www.sidefx.com]
Ahh!
Thanks.
-Olivier
