[Python] Failed to modify node or parameter because of a permission error
   8649   7   1
In the PythonModule of my digital asset I have this function:
def setChildParm(node):
   node.parm("/pathToNodeInsideOtl/parm").set(value)
The function, which is called by a button on the OTL, is trying to set the value of a parameter belonging to a node inside the same digital asset.
I get the following error whenever I try to run the function:
PermissionError: Failed to modify node or parameter because of a permission error. Possible causes include locked assets, takes, product permissions or user specified permissions
That's because the digital asset is locked, so I have to allow the editing of content of the OTL in order to make it work.
But this is not what I want to do.
What's the proper workflow with python to set a parameter of a node inside the digital asset?
Any help very appreciated,
cheers
Edited by Andr - Feb. 1, 2019 16:17:06
you can make the node inside Editable, or you can promote that parameter to the top level and make it invisible.
Training Lead
www.sidefx.com
hey Micheal, thanks for the tip!
The node inside is a simple null, so it's already “unlocked”..
I'll try the second option you mentioned.
Cheers!
goldfarb
Hello!
How do you make the node inside Editable?
fdevic
goldfarb
Hello!
In the OTL type properties tab for that HDA there is a section under the Node tab to add editable nodes
how can i delete/create nodes in a locked hda from the python module?
i am using a button with a callback script that runs a delete() function
for n in node.children(): n.destroy(True)
i get an error message that i don't have permissions because the asset is locked. Is there a way around this?
papsphilip
A locked HDA can't change its contents. However, an HDA can contain an editable subnet which can be manipulated.
jsmack
papsphilip
Yes thank you! i got the same answer here
https://forums.odforce.net/topic/49591-python-module-createdelete-nodes-inside-locked-asset/ [forums.odforce.net]
its working
callback_parm_kwargs_hda_node.hip (89.4 KB)
