Heightfield output no 4k on Indie
   3458   5   1
When i use heightfield output node the resolution is limited to 1920x1080, i read that houdini indie license for one frame has 4k limit resolution.
Thanks so much
Just tried this and H actually writes a file that is 4096x4096 but it only fills the bottom left 1920x1080 pixles.
-b
http://www.racecar.no [www.racecar.no]
Same to me, if i dive into Network all is ok, but when you save to disk only fills the bottom left
This is also a problem that I am having.
I trust all 4 of you have submitted bug reports?
https://www.sidefx.com/forum/topic/25347/ [www.sidefx.com]
That`s OP`s privilege…
-b
