Vellum glue constraints rotation free
   2270   5   2
Is there a way to free vellum glue constraint rotation twist?
https://vimeo.com/user2163076 [vimeo.com]
It seems that most of the vellum constraints are rotation locked I would like to change that like when I use pin constraints and set the type to ‘position’, any tips?
I am going to try this again, I am trying to find out how to unlock the rotation on vellum constraints like we can do to RBD constraints using the “constraint_type” attribute to “position”, is it possible to do that?
(SOLVED)
Thanks.
Edited by mzigaib - Oct. 24, 2019 14:14:02
Please post your solution, instead of SOLVED. That's no help to anybody else.
Cheers
I have same problem and attached a sample scene to test
Does anyone know how to solve this, unable to restrict the rotation of the glue constraint.
glue just pins the point position.
Thanks in advance.
vellum_glue_rotations.hiplc (702.0 KB)
Mohan Pugaz
movfx
