Hi;
I’m looking for some documentation/Tutorial about “Action Button” tab in “Edit Parameter Interface”.
Thanks for helping.
I’m looking for some documentation about "Action Button" tab in "Edit Parameter Interface"..
6249 6 1- Masoud
- 415 posts
- goldfarb
- 3464 posts
- Masoud
- 415 posts
- goldfarb
- 3464 posts
- tamte
- 8833 posts
Masoudthere is not much else to it
Is there any tutorial about how to work with this?
so as mentioned on the goldfarb's link
- put a code in there that you want to be executed when the action button is clicked
- use kwargs dictionary variable to access some intrinsic data (node, parmtuple, …)
so overall it's similar to setting up a parameter callback for a button
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- vinyvince
- 275 posts
What confuse me is why this is the action button section is to accessible (empty) with a button parameter?
Only in with an event. I tried to build one but for now im failing
tamteMasoudthere is not much else to it
- use kwargs dictionary variable to access some intrinsic data (node, parmtuple, ...)
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
- vinyvince
- 275 posts
Edit i found some answer but so far i didn't found great use of the action button feature compare to a simple button with a callback.
Until the moment when i decided to boost the default Sidefx "Null" with a bunch of additional features. It's not an HDA so there is no script module attached and if you could execute a bunch of python instructions in a single line format, it's rather limited!
But with action button , you could run a full standard python script that way !
Very handy... i don't think people know this so i thought was worth sharing
Edited by vinyvince - Sept. 9, 2024 16:20:39
