fur redshift proxy export in houdini to maya
   Views 10834   Replies 3   Subscribers 0
Hi beautiful people there,I am working on a fur project in Houdini 17 and I had a problem with rs export.My exporting process is basically that converting hair display to a geometry.I think it should be work but my rs file didnt work.I shared related files additively.You can check easily and help me .Thank you guys.
Try the same thing again with the “Redshift Proxy Output” under SOPs. That should do the job!
I am having the same issue, no matter if i do it in SOPs or the rop context, I cant seem to get curves to export as .rs
Hi!
Consider sharing this on the Redshift Forum, Side FX is not involved in RS plugin development:
https://redshift.maxon.net/category/26/bugs-houdini [redshift.maxon.net]
