I'm working on a digital asset, which in its basic form
just includes a grid followed by a group SOP. I've promoted
the group SOP's basegroup parameter to the asset UI and would
like to use it to select faces on the grid and add it to the
group.
However, when I hit the action button, I get an error popup:
File “Parameter Scripted Action”, line 4, in <module>
AttributeError: ‘NoneType’ object has no attribute ‘eval’
If I only use a grid and a wrangle with the string parameter
and the action button, which works fine inside the asset, the
message that comes up says:
Not enough inputs connected to select this group.
I haven't really found anything about either in the forums or
on google, so I thought maybe someone here has encountered this
before.
Any help is appreciated.
