[SOLVED] Installation_check error and bad path to ImageMaigck/FFMPEG (on Windows)
   4387   2   0
I get the follow error message when I {shift}+{V} on any node in Installation_check.hip
I opened the file via shelf>“TOPs Utils”>Installation Check
Note: “Zugriff verweigert” means “Access denied”
Error
Error running callback 'onStartCook': [Error 5] Zugriff verweigert: u'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.173/houdini/pdg/installation_check/pdgtemp'
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.173/houdini/pdg/types\schedulers\local.py", line 195, in onStartCook
os.makedirs(self.tempDir(True))
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.173/python27\lib\os.py", line 150, in makedirs
makedirs(head, mode)
File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.173/python27\lib\os.py", line 157, in makedirs
mkdir(name, mode)
WindowsError: [Error 5] Zugriff verweigert: u'C:/PROGRA~1/SIDEEF~1/HOUDIN~1.173/houdini/pdg/installation_check/pdgtemp'
Specs:
Windows 10 Home
Houdini Indie 17.5.173
Can I fix this, or should I check with support?
I also installed ImageMagick and added
PDG_IMAGEMAGICK="C:/Program Files/ImageMagick-7.0.8-Q16"
PDG_FFMPEG="C:/Program Files/ImageMagick-7.0.8-Q16"
to my environment variable file. Does this look correct? Do I need to add something else?
Edited by DASD - March 16, 2019 22:28:23
Hi, it looks like it is trying to create the pdgtemp directory but it's failing to because it's in C:\Program Files and doesn't have administrator privileges. You can work around this by copying the installation check folder to somewhere else or using the merge into current .hip file option on the shelf tool.
For the environment variable, make sure it points to the actual executable:
PDG_IMAGEMAGICK="C:/Program Files/ImageMagick-7.0.8-Q16/magick.exe"
Edited by BrookeA - March 16, 2019 21:19:36
Great that worked!
Saved the hipfile in a folder outside of Program Files and then had to point the filepattern nodes to
C:/Program Files/Side Effects Software/Houdini 17.5.173/houdini/pdg/installation_check/input/images.zip
instead of the relative path.
Then I changed the environment variables to:
PDG_FFMPEG="C:/Program Files/ImageMagick-7.0.8-Q16/ffmpeg.exe"
After that I could cook the nodes as expected.
Edited by DASD - March 16, 2019 22:31:49
