Hi!
I've imported a camera with the Alembic Archive node. When I press play, I can see the camera animated.
When I dive down, I can see a Camera node with it's world transforms animated (t, r, s). If I dive once more, and press play, there's no animation and the camera is at the origin and my perspective is sideways…
How can I access the position(@P) and orientation(@N) so I can so I can pass it through a wrangle? I'm trying to create a point/N per frame.
-Olivier
imported .abc camera: how to access position/orientation with a wrangle? SOLVED
3676 2 0- olivierth
- 1075 posts
- jsmack
- 8045 posts
In a separate object's pointwrangle:
(You can also object merge the point from inside the camera object into your source object. If you need the z axis, add N to the point inside the camera with a value of {0,0,-1})
string camera = "/obj/alembicarchive1/Camera2/CameraShape2"; // path to your camera @P = ptransform(camera, "space:current", {0,0,0}); @N = ntransform(camera, "space:current", {0,0,-1});
- olivierth
- 1075 posts
