VDB Reshape SDF Error
   3896   4   2
Hey, I've been trying to use the VDB Reshape SDF node, but it's not working, and kicking up this error for me:
“VDB primitive density was skipped because it is not a level-set grid.”
Can anyone tell me what that means, and how to solve it? Thanks!
Hey there,
I have this same problem, Did you manage to find a solution?
I am having the same problem, driving me crazy, did you manage to find the solution?
VDB Reshape SDF SOP works only on SDF (signed distance field) aka Levelset volumes
that warning just means that you are trying to run it on density/fog volume or that at least some of the volume primitives in your geometry are density/fog volume
FX Supervisor
Method Studios, NY
work around is to convert to vdb,class fog to vdb then do the operation then convert class back to vdb to fog.
Houdini Fx Artist (Build)
