Volume copy to points
   Views 1119   Replies 0   Subscribers 0
Hi all.
I'm trying to copy the output of a pyro sim to a number of points on a mesh using copy to points. This part works fine, the issue I'm having is that I need to correct the orientation of the vel field once the orientation of the volume has been modified.
What's I don't understand is how to get the normal value from the point to modify a specific vel field on a volume (as there is now an arbitary number of vel.x, vel.y and vel.z fields in the node).
Any help would be appreciated.
