Feature Idea : Add a "warning" mode to Json Input node is key doesn't exists
   1996   1   0
Json Input node works pretty well ! But I figured out that if you do a query on a key that doesn't exists, node returns an error.
It would be nice to add a mode that returns warning if key doesn't exist (same as file node if frame doesn't exist), but continue reading / graph execution.
(I found a workaround using pyhon and try/except to read json data).
Paul.
Edited by Paul Parneix - April 17, 2019 12:51:02
FX TD @ Unit Image (Paris) / 3D Scan Specialist.
I agree this would be a good idea!
I've logged an RFE for it. Thank you!
