Can we create a digital asset that uses a single input 0 and multiple inputs after?
I've seen this for some nodes inside Houdini although I can’t find them right now. But I made a Photoshop montage of what I would like to do. The first input on the left is the mandatory one and all others are using a bar like the right part of the input.
Possible to do currently?
Thx!
Christian
Single + Multi node inputs...
4766 7 1- cs_pix
- 23 posts
- goldfarb
- 3464 posts
- vinyvince
- 275 posts
Any plan to change this maybe ?
Vincent Thomas (VFX and Art since 1998)
Senior Env and Lighting artist & Houdini generalist & Creative Concepts
http://fr.linkedin.com/in/vincentthomas [fr.linkedin.com]
- juejuezi
- 34 posts
- viklc
- 222 posts
forever_kkgoldfarbCan I achieve it with HDK?
this isn't currently possible for user defined nodes.
I couldn't find the HDK code to achieve it
The only thing you can do is set the input amount to a value, as in the figure below, to 28+ (depends on the gui scale?), to merge the inputs into a single one - but this does not behave exactly like the input in the merge op.
Edited by viklc - Aug. 1, 2023 11:19:28
- juejuezi
- 34 posts
vik_lcThank you for response.forever_kkgoldfarbCan I achieve it with HDK?
The only thing you can do is set the input amount to a value, as in the figure below, to 28, to merge the inputs into a single one - but this does not behave exactly like the input in the merge op.Image Not Found
But I need single + multi.
Because I need to type different things, I need to make a distinction.
- viklc
- 222 posts
- danyargici
- 19 posts
