Vellum cloth to rigid metal like material
11992 5 1-
- Kwesikwaa
- 21 posts
What is the best approach to make quasi-hard materials like metals from vellum cloth. I am successful with tweaking stretch and bend plasticity values but the grid still feels quite flappy. Help on how to take the soft, cloth like feel out of it to make it feel like a hard metal sheet. I am looking at this as alternative to the RBD approach to creating dent or bending in car crash situation or even metal pillars. Help would be very much appreciated
- Enivob
- 2658 posts
- xilofoton
- 85 posts
Good hint.
… and also increase the Substeps, the default 1 is very low. Try 10 or if you have time/fast machine, even more.
If you can access the actual 3D Artist mag check my tutorial which is partially about pseudo rigid bodies with Vellum, how to use helper constraints (with the limits of printed media…), but your metal sheet stuff is the most difficult to achieve properly.
Additionally you can add thickness (Game Tools/Thicken is the best) to the surface and threat it as Strut Softbody. The Thickness in the constraint node is a bit strange, higher values can significantly slow down the simulation.
- Kwesikwaa
- 21 posts
- 5DN
- 152 posts
- cocopops69
- 4 posts
