Hello everyone,
i've installed Renderman 22.5 for Houdini 17.5 and set up the houdini.env file as written in the Renderman Documentation. If I start Houdini, I always get this message in the console:
Unable to find libprman. Resorting to backup string table. Rendering will error
Error running pythonrc.py:
File “C: /Program Files/Pixar/RenderManForHoudini-22.5/17.5/python2.7libs/pythonrc.py”, line 41, in <module>
import rfh.config # relies on PYTHONPATH having been set above
File “C: /Program Files/Pixar/RenderManForHoudini-22.5/17.5/python2.7libs\rfh\config.py”, line 49, in <module>
from node_desc import NodeDesc
File “C: /Program Files/Pixar/RenderManForHoudini-22.5/17.5/python2.7libs\node_desc.py”, line 55, in <module>
from txmanager.txparams import TXMAKE_PRESETS
ImportError: No module named txmanager.txparams
The Renderman-Part in my environment file looks like this:
RMANTREE=“C:\Program Files\Pixar\RenderManForHoudini-22.5”
RFHTREE=“C:\Program Files\Pixar\RenderManForHoudini-22.5”
HOUDINI_PATH=$HOUDINI_PATH;$APPDATA\SideFX\GameDevToolset\17.5\1.159;$RFHTREE\17.5;&
Do you guys have an idea, how to fix this issue?
Best Regards,
Chrizzo
Renderman 22.5 for Houdini 17.5 issue on start
5940 6 1- Chrizzo
- 8 posts
- raschberg
- 20 posts
- Chrizzo
- 8 posts
raschberg
Hi
your entry for RMANTREE looks wrong to me, it should point to ProServer like this:
RMANTREE=“CProgram Files/Pixar/RenderManProServer-22.5”
best regards
(eh- without the emoticon, this is a bug from the website)
Yeah! It fixed the issue!
Thank you very much
Edited by Chrizzo - May 9, 2019 15:26:42
- dkzone
- 23 posts
- cgbeige
- 99 posts
- nisachar
- 83 posts
- dkzone
- 23 posts
