Hello.
I just installed Houdini 8.1 Apprent. in Linux sucessfully. But i am no Linux Expert (yet).
I have just one simple Question :
Instead of having to type “source houdini_setup_bash” in the Shell to init the environment where in Linux have I put this to be auto-init. at Startup ?
Automatic source houdini_setup_bash ?
5166 3 1- Vertex23
- 4 posts
- rdms
- 201 posts
Vertex23
Hello.
Been awhile since using unix but I believe you can put into your .login file an entry like:
pushd <directory _where_bash_shell_is_located>
Good luck.
Rob
Rob
Digital Supervisor | Stargate Studios Toronto
Rob
- Pagefan
- 519 posts
You could do several things….
a) make a little script that cd's to the houdini dir and then starts houdini; something like this
#! /bin/bash
cd /where_ever_is_houdini/hfsx.x.x.x
You can run this from the command line. I put houdini in the /opt directory and make a link called hfs referring to hfs8.x.x.x. Imho easy way to maintain (installation) scripts as i only have to change the link when installing a new apprentice version.
b) like (a) but then make the script in KDE/Fluxbox/Gnome
add a menu entry and as startup command use this
cd /where_ever_is_houdini/hfsx.x.x.x && source houdini_setup_bash
If you search on the forums here you can find a nice svg icon someone made to use as icon (btw, thanks someone, it's a nice shiny logo)
c) rework the houdini_setup_bash and add it to your startup profile…Done that here and it works like a charm. Can start houdini everywhere, anytime. Not sure if “shops” do it like this, there might be some pitfalls…
Hope this get's you started. Just play a bit with bash and your windowmanager, you'll manage. And have fun with houdini and linux!
#! /bin/bash
- Vertex23
- 4 posts
