MSI GL63 8SE Houdini crash
3591 4 2- AnnaTronci
- 7 posts
- Sadjad Rabiee
- 1391 posts
Hi
One reason could be for MSI audio software !
In most of the MSI laptops there is Nahimic audio software which has conflict with Houdini !
Seems like it is using VGA drivers too.
You can try to uninstall it or you can delete some of it's DLLs.
If you check Houdini log file when crashing, it would tell you which DLLs of Nahimic are cause of the problem and you can delete them.
For mine there was a x64 folder in Nahimic installation directory and I,ve renamed it to other name.
I don't have any other solution and I hope it will be useful for you aswell.
Edited by Sadjad Rabiee - May 19, 2019 07:25:27
- AnnaTronci
- 7 posts
- Sadjad Rabiee
- 1391 posts
- AnnaTronci
- 7 posts
I finally solved! Changing the Folder name….Reamni this problem :
“Could not create OpenCL device of type (HOUDINI_OCL_DEVICETYPE): GPU on platform vendor (HOUDINI_OCL_VENDOR): Intel(R) Corporation. Falling back to built-in CPU OpenCL driver”
My laptop has an rtx 2060 and an integrated intel Gpu card…
Thanks in advance
Thanks in advance
