Hello all,
I created a simple fluid sim which I am trying to bring over to UE4. Everything is setup correctly as far as I can tell. I followed this tutorial: https://www.sidefx.com/tutorials/game-tools-vertex-animation-textures/?collection=50 [www.sidefx.com]
However my object seems to have half of the faces missing for some reason (see image below)
I have full precision UVs enabled as well per the tutorials suggestion, running UE4 4.22 and Houdini 17.5
Vertex Animation to UE4 problem
5167 3 1- pmcavena
- 2 posts
- mikelyndon-sesi
- 394 posts
- 3DBandi
- 6 posts
Hello!
I tried to export an rbd simulation to Unreal. I used animation_vertex_texture ROP for that. I followed the video https://vimeo.com/212982381 [vimeo.com] (which is a great video).
But when I exported the packed objects I got a bad motion, it appears as the fragmented pieces had a bad pivot. So I tried to export an unpacked object. In that case the tool seems to create a 0 rot map. And save just the positions of the vertices and I got a correct motion in unreal.
So something seems to be messed up while creating the rot map. Do you have any idea, why I got a different result then in the masterclass??? What should I be care while creating rot map???
Thank you.
Thank you.
- SlaterGT
- 4 posts
