I can't seem to get the heightfield visualize node to work with the sop_mapbox (GameDevToolset) node anymore. I've attached 2 screenshots, one showing it working (old file), the other not.
Same settings on each. Using H17.5.258 & GameDevToolset 1.173.
Anyone else having this problem?
heightfield visualize not working
3864 6 1- DevoStevo
- 35 posts
- asm
- 31 posts
Just tested on H17.5.258 and GameDevToolset 1.173, same issue. If I temporarily replace sop_mapbox with a HeightField, the ramp color (temporarily) appears.
mapbox_on_steroids however seems to work fine. I notice mapbox_on_steroids doesn't create a shop_materialpath attribute so might have something to do with that.
Edited by asm - June 24, 2019 15:39:48
- DevoStevo
- 35 posts
- sonoker
- 1 posts
What worked for me for some reason is creating the Heightfield visualise connected to another Heightfield, and then disconnecting it and connecting it to the correct heighfield (in this case mapbox)
Then it allows me to edit it. when I just created it connected to the mapbox it doesnt update, but then if i connect that one to another heightfield it works…
- mixakmix
- 1 posts
- BrianPow
- 2 posts
- AlokPepakayala
- 1 posts
