Blur multiple heightfield layers
   1916   2   0
Hi, I'm trying to go over all my heightfield layers and blur them a bit.
I first wanted to do this in vex in an attribute wrangle but couldn't find the correct function.
Then I tried adding multiple layers in the heightfield mask node but it would only accept the first one.
Obviously I'd like to avoid then blur nodes.
Edited by neo_Flore - June 24, 2019 04:59:40
Did you try to put * in the Blur Layer ? * means it selects all the elements. You can put * ^height ^mask to select all except height and mask.
Using * worked for me, it blurred my height field and my mask too.
Ah cool, I didn't know the ^ was a thing.
That solution helped, thanks!
