MPLAY not launching
   Views 3177   Replies 7   Subscribers 1
For some reason i dont understand mplay is not launching. My gpu drivers are updated, and i ve tried very simple scenes like a cube rotating, tried to do a flipbook but it crashes every time. in the task manager it says houdini is not responding and the only thing thart is different lately is that this error message appears when i launch houdini.Maybe this has something to do with it?I havent upgraded to a newer version of Houdini, i m still running 17 version and flipbooks worked before.
But it does work when i save directly to disk!
Any ideas?
“= = = = Viewer states registration = = = =
Error: CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/viewer_states/sidefx_bend.py
File ”<stdin>“, line 1, in <module>
File ”CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\stateutils.py“, line 563, in register_pystate
hou.ui.registerViewerState( template )
File ”CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hou.py“, line 56947, in registerViewerState
return _hou.ui_registerViewerState(*args)
NameConflict: Name conflict was detected.
Error registering ‘sidefx_bend’: already registered.
Error: CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/viewer_states/sidefx_lop_edit.py
Error registering ‘sidefx_lop_edit’: already registered.
Error: CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/viewer_states/sidefx_stroke.py
Error registering ‘sidefx_stroke’: already registered.”
Edited by papsphilip - July 2, 2019 15:44:47
I've seen this one in the past which was partially fixed in 17.0.425. Could you post your environment settings you are using to replicate the problem ?
_mab_
How can i do that? you mean the houdini.env file?
Help > About Houdini > Show Details
Training Lead
www.sidefx.com
_mab_
Here are the environment settings
Houdini_Info.txt (16.0 KB)
Ok Could you please post the python files you have under these folders ?
CProgramData/Redshift/Plugins/Houdini/17.0.416
CUsers/User_/AppData/Roaming/SideFX/GameDevToolset/17.0/1.179
CUsers/User_/Documents/houdini17.0/viewer_states
dir *.py /s
_mab_
dir *.py /s
i'm not sure what is the code you posted but here are the files!Couldnt find the last one
gamedevutils.py (3.1 KB)
gamedevutils.pyc (3.7 KB)
githubdownloader.py (11.6 KB)
hou_settings.py (1.4 KB)
houdini_external_editor.py (9.2 KB)
houdini_external_editor.pyc (8.7 KB)
redshift.pypanel (3.6 KB)
sidefx_bend.py (10.0 KB)
sidefx_bend.pyc (10.3 KB)
sidefx_lop_edit.py (2.6 KB)
sidefx_lop_edit.pyc (4.2 KB)
sidefx_stroke.py (23.7 KB)
sidefx_stroke.pyc (24.4 KB)
I wasn't able to reproduce the problem with 17.0.416. A fix was added to 17.0.425, can you try with 17.0.459 or 17.0.506?
