How to delete/replace a String parameter reference in python
   3164   1   0
When a string parm is set with a hscript reference to another parameter, how can we delete or replace this reference?
If I simply do set, it will change the value of the referenced parameter and deleteAllKeyframes() does nothing…
The only solution I found at this time is the next:
p = hou.parm('/obj2/geo2/file1/file')
if p.getReferencedParm() != p:
    p.revertToDefaults()
p.set('`chs("../../geo/file1/file")`')
Or change this to an expression…
Am I wrong or there is no other way?
Edited by ppiche - July 9, 2019 18:09:05
I guess in this case you need to use the setExpression() function, instead of the regular set().
it's documented here: https://www.sidefx.com/docs/houdini/hom/hou/Parm.html [www.sidefx.com]
cheers
