Attribute Value as Label?
6412 9 1- subscriptions
- 28 posts
How do I use the value of a detail attribute as a Label in the Edit Parameters Interface?
I'd also be fine if I could add a float parameter and put an expression in the field that would display the value.
I tried many variations of `print detail.attribValue(“cost”)`
Trying to display the value of a findshortestpath cost attribute.
Thanks,
Tim
Thanks,
Tim
- animatrix_
- 4719 posts
Try:
Try:
`detail(0, "cost", 0)`
- Andr
- 899 posts
animatrix3d
Try:`detail(0, "cost", 0)`
Ohh, it would super nice if the Label field of the editor interface could also accept hscript.
A lot of less time wasted working with parmgroup templates.
I wonder if there's any valid technical reason for not being able to do that?
Anyway, if you want instead to change the label itself, you can use the following code.
Have a look at the attached example file
node = hou.pwd() targetParm = node.parm("targetParm") newLabel = node.parm("newLabel").eval() group = node.parmTemplateGroup() oldParm = targetParm.tuple().parmTemplate() newParm = targetParm.tuple().parmTemplate() newParm.setLabel(newLabel) group.replace(oldParm, newParm) node.setParmTemplateGroup(group)
Edited by Andr - July 24, 2019 03:55:15
- subscriptions
- 28 posts
- Mohanpugaz
- 146 posts
Expressions in label works for me
using H17.5.327
using H17.5.327
Mohan Pugaz
movfx
movfx
- HaniJahan
- 14 posts
- tamte
- 8810 posts
You need to use details() [www.sidefx.com] function for string
Edited by tamte - July 27, 2023 10:36:28
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- HaniJahan
- 14 posts
tamte
Thanks! I was trying details() function like this
`details("../OUT", "test")`
`details(0, "test")`
However this one worked
`details("./OUT", "test")`
not sure why ../ not working here
Edited by HaniJahan - July 27, 2023 14:39:31
- tamte
- 8810 posts
Hannah Jahanshahiit's because it results in an invalid path
lets say your node is at "/obj/geo1/test_attrib_name"
since your OUT node is inside your HDA, relative path: "./OUT" or potentially also just "OUT" will result in a correct full path "/obj/geo1/test_attrib_name/OUT"
however relative path "../OUT" will result in "/obj/geo1/OUT" which is most likely nonexistent, but even if it existed and would work, it's undesirable as it's outside of your HDA and therefore not self contained
Edited by tamte - July 27, 2023 18:08:12
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- pandapin223
- 1 posts
