mapbox in houdini
   4521   5   1
Hi
I have Houdini Apprentice 17.5.258. l'm make terrain using GameDev Mapbox(Beta).
But I have a problem.
I connected the heightfield_visualize to mapbox node but it does not work.
Is there a solution to this problem?
I tried to follow the tutorial at https://www.youtube.com/watch?v=n8AL-_gkIZQ [www.youtube.com]
You have to delete the sat layer i guess befor visualize
Forgive my newbie-ness but I'm having the same issue - heightfield visualize seems to do nothing. I have no idea what the sat layer is or how to delete it - can you elaborate please?
Also, the path height png that gets generated by the mapbox node seems to have value in all 3 color channels, can someone tell me what each channel represents?
I have exactly the same issue. I just want to take the heightmap from the mapbox terrain and I cannot find a way to do it with Houdini.
I tried 17.5 and 18 both Apprentice and Core versions and it doesn't work.
Add an “attribute delete” node and delete the “shop_materialpath” primitive attribute.
Thank you so much man! It totally works.
