Mantra - two sided
   2956   2   1
Hello!
I am trying to use the mantra two sided vop but can't seem to get it to work.. Do you plug to output of the two sided into the diffuse amount?
thank you in advance!
It totally depends on what exactly you're trying to blend. If you want an object to have one diffuse color on one side and a different one on the other, then yes, plug the output color into the diffuse slot of your material. If you want to blend entire materials, change the Signature to BSDF and then plug the output “F” of each material into the two sided VOP, then connect the output to the output globals F.
Thank you! I am going to try this right now..
Sorry for such a late reply!
- Manan
