Mantra not working after installing Redshift
   Views 6856   Replies 9   Subscribers 2
Mantra stopped working after installing Redshift.
Does anyone has any solution for it. I have setup env file as mentioned in Redshift installation guides.
HOUDINI_DSO_ERROR = 2
PATH = “CProgramData/Redshift/bin;$PATH”
HOUDINI_PATH = “CProgramData/Redshift/Plugins/Houdini/17.5.229;&”
I am using Houdini 17.5.229, Redshift 2.6.41, Windows 10 and GTX 1070 Ti
What error do you receive when you attempt a Mantra render?
Houdini Indie
Karma/Redshift 3D
I have the same issue. I am not getting an error message. It says just “generating scene…” on the render view tab. or if I try to open the render panel with a mantra node than there is a nothing. Render screen is not opening. If I delete the redsift code in the env file than everting is ok. Mantra is working.
Edited by omerkucuk - Aug. 22, 2019 18:48:09
@Daryl, mantra doesn't show any error, just generating scene and it continues forever.
But i never get the output.
Kanitk86
I have the exact same issue, have you solved it?
Z./
I have almost the same built as you @Kanitk86 and the exact same issue…. to add on to the problems it even screwed up my Mplay Image viewer and my Geometry Viewer which now don't start anymore.
Anyone found a sollution yet?
Edited by LuFu83 - Oct. 23, 2019 17:46:02
I have the same issue too. any solution for this?
I was just running through a tutorial from Etnagma and also got issues with using Mantra, it can't seem to find a license even though I'm running the Indie version. Has Solaris broken Mantra rendering, or installing my Octane Studio license broken it?
I really want to finish the final steps of the tutorial and want to stick with Mantra for the time being.
Did anyone ever fix this? I'm having the same issue
I fixed issue by enabling RedShift via json package.
In my case the problem was on a macbook m1.
I tried to configure RedShift via
houdini.env
but mantra stopped working.
After a little digging I noticed that removing
PATH
section from
houdini.env
helps. I haven't tested this well enough so this solution may cause problems
Anyway, I created
/Users/YOUR_USERNAME_HERE/Library/Preferences/houdini/HOUDINI_VERSION/packages/redshift.json
file and put the next content to it:
"env": [
{ "RS_PLUGIN_VERSION": "20.5.370_arm64" },
{ "REDSHIFT_COREDATAPATH": "/Applications/redshift" },
"HOUDINI_PATH": "${REDSHIFT_COREDATAPATH}/redshift4houdini/${RS_PLUGIN_VERSION}"
{ "PATH": "${REDSHIFT_COREDATAPATH}/bin" },
"PXR_PLUGINPATH_NAME": "${REDSHIFT_COREDATAPATH}/redshift4solaris/${RS_PLUGIN_VERSION}"
Make sure you set the
RS_PLUGIN_VERSION
to correct one.
I hope this helps someone.
