Primitive colors
2419
2
0
dremnerd
Aug. 5, 2019 10:12 a.m.
Hi I've made an effect using Houdini primitives and they have colors. when I convert them to poly they get white and loose color data. How should they convert to pass this problem. Thanks Mojtaba
tamte
Aug. 6, 2019 4:01 p.m.
If you mean packed primitives then do Unpack SOP first where you can specify which attributes to transfer to unpacked geometry If you then still need to convert it should keep the attributes
Tomas Slancik FX Supervisor Method Studios, NY
dremnerd
Aug. 10, 2019 6:29 a.m.
tamte If you mean packed primitives then do Unpack SOP first where you can specify which attributes to transfer to unpacked geometry If you then still need to convert it should keep the attributes Thanks Tomas
