Hello everyone.
I have a long sequence where changes happen in the geometry, I have an attribute that changes to 1 whenever the geometry change happens. I would like to store which frames the attribute jumps to 1 in something like an array, does anyone know whether this is possible in VEX? and if so how?
I hope I am clear enough in what I want.
How to store frame numbers based on attribute
2337 1 1- Yehbe
- 47 posts
- Tanto
- 458 posts
Yes, VEX can do that! Create an array attribute, then use a solver to compare the current frame's value to the previous one's, and push [www.sidefx.com] @Frame to your array if your conditions are met. In a wrangle node, with your current frame in input 0 and previous frame in input 1:
Hope that helps.
f[]@frameArray; if(@testAttribute == 1 && @testAttribute != @opinput1_testAttribute) push(@frameArray, @Frame);
Hope that helps.
