I recall seeing an example some time ago of a procedural way to animate the FirtU and SecondU parameters of the Carvev SOP making it cycle/loop. I can't find that reference anymore, any idea what that expression would be please? (I am not referring to Matt's carving examples, which are awesome https://forums.odforce.net/topic/30668-randomize-carve-animation [forums.odforce.net] , because those are ping-pong-ing and i need to cycle/loop instead)
To be more precise, what it should do, what i'm trying to get, is it makes it look like a chunk of the curve is permanently sliding along its path and cycling.
Thanks in advance,
A.
Cycle Carve SOP animation?
2378 2 2-
- Adriano
- 411 posts
- blubbmedia
- 26 posts
When you reach the end of the curve, you would probably want a second curve to appear. The following code does not take care of that, but it does loop your curve segment.
Put it into a Wrangle, set it to “detail”, and let the Carve SOP behind it reference detail(0, “first”, 0) and detail(0, “second”, 0)
float amount = @Frame / 100;
f@first = frac(amount);
f@second = frac(amount + 0.2);
if (f@second < f@first)
f@second += 1;
f@second += 1;
- Matttrebor
- 3 posts
