COP file node, load by filePattern?
   Views 3157   Replies 1   Subscribers 1
I'd love to auto-detect and load texture files when creating materials. I often have a subfolder with 4 files: diffuse, specular, roughness, and normal- and they're named with a pattern. Is there a way to have the cop file node automatically detect the (*_roughness.png) file if I tell it the directory to look in?
In a perfect world, I'd love to make an HDA with an exposed folder location: I tell it the subfolder, it makes a material out of the png maps inside. Is this possible? Thanks!
Hi
You can use below python script for doing this :
import glob
subF = "PATH to SUBFOLDER"
file = subF + "*_spec.jpg" #PATTERN
a = glob.glob(file) # SEARCH FOR FILE
return a[0] # RETURN FULL PATH OF THE FILE
check attached project
JKCOP_File.hip (54.5 KB)
Rabiee.Sadjad@Gmail.Com
