Hello ,
is there somewhere a tutorial that explains and demonstrates this?:
RenderMan Shader Builder
Houdini’s VOP shader building has a separate context for creating RenderMan shaders. In this context, shading artists can create RenderMan shaders interactively, using a node-based system, without writing code. The shading network is built up of pieces that represent snippets of native RenderMan code, which means that the resulting shader is not a conversion of a Houdini shader but a properly coded, clean and optimized RenderMan shader.
thanks in advance,
bern
Houdini Renderman tutorial?
3717 5 0-
- Bernard
- 523 posts
- JColdrick
- 4140 posts
I'm not near Houdini right now in terms of pointing you to specific examples, but it basically offers node based shader building, just like the VOP shaders, but exports renderman shader code instead of VEX. If you're familiar with shading with VOPs(which has some help entries), then it's the same deal, except of course the shading language is different and you'll need to be somewhat familiar with it to do much useful with it. I suspect that's why there's no examples per se - it's expected you're an rman user to have much use for it.
J.C.
J.C.
John Coldrick
- Bernard
- 523 posts
JColdrick
J.C.
Thanks JColdrick,
When I go to VOPs and lay down a VEX surface shader, go in to it and connect a Stone vop to the Output vop…I can Create New Shop from VOP Network.
Now when I lay down a RSL Surface Shader and do the same as above, I can Not create a New Shop From Vop Network. It's not in the menu.
How can I create a ‘Renderman’ Shop to use with Houdini?
thanks,
bern
- JColdrick
- 4140 posts
- Bernard
- 523 posts
- JColdrick
- 4140 posts
