I find Polyexpand2d SOP is so important in procedural modeling, it can generate straight skeleton, simple road, hip roof and so on.
And some NURBS SOP like fit / refine are also necessary for procedural modeling.
I think the official progress of making SOP compilable is a bit slow.
Will Polyexpand2d and some NURBS SOP be compilable in Houdini 18?
3207 5 1- zengchen
- 77 posts
- EricSheng
- 159 posts
- davide445
- 54 posts
- zengchen
- 77 posts
davide445
@zengchen01 can you explain how do you use it to generate simple roads, or suggest any specific tutorial you follow.
The road I generate by Polyexpand2d SOP is quite simple.
I think this road tutorial is more useful.Dokai Tutorial [vimeo.com]
Edited by zengchen - Oct. 11, 2019 20:41:14
- davide445
- 54 posts
zengchen01I've seen this tutorial but seems really complex for a beginner like me.
Simple roads are fine if also the setup is simple :-).
Can you point me out in the right direction.
Edited by davide445 - Oct. 12, 2019 06:22:13
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
- zengchen
- 77 posts
davide445
Dokai's tut seems a bit complex, but honestly it still has a lot to improve for the Game output…
As for the polyexpand2d SOP, when create simple road, it can not generate UVs.
And I do not use polyexpand2d SOP to generate streets based on the OSM data, so I think you wouldn't get any more help from me…
Here is an simple example about polyexpand2d SOP itself, hope it works for you.
Edited by zengchen - Oct. 13, 2019 03:08:32
