IK FK problems
   1270   2   0
Hi there,
I'm running into problems with IK and FK constraints. Even bypassing all the blend stuff in the constraints network and output the “Get World Space” node directly doesn't bring IK to work. Only if constraints are disabled on the bones, IK works nicely again.
Changing the range in the “Get World Space” node to “Use Full Animation Range” from “Use current frame” makes it work, but is that the correct setting? Initially it's “Use current frame”. Don't want to solve one problem and generating another by the wrong solution.
What's correct, or is there a bug with constraints in 17.0.374?
Cheers
Tom
there were a few updates/fixes to constraints in 17.5
if you can I'd suggest updating to the latest Production Build - as of this writing that is: 17.5.391
post again if this help you out
Training Lead
www.sidefx.com
Works after update so far! : )
