Hi, first post. Sorry if this is in the wrong place or a silly question. I'm just getting started with Houdini, and I'm really liking it!
Here's my question: I'm trying to animate a character. I want him to run for awhile, slow down, stop, etc. My idea was to use the animation layers and create a looping running cycle, and animate it's influence down to zero when he's not moving. Scrubbing the value from 1 to 0 manually creates the blend I'm looking for, but when I keyframe the transition nothing happens. I can see the value change in the animation mixer window but the run cycle remains visible.
What am I missing?
Blending animation layers
2312 4 1- wenglish
- 5 posts
- rlinck72
- 3 posts
- toonafish
- 475 posts
Same here.
Is it possible to animate the blending of several animation layers in Houdini ?
I'm trying to figure out how to use animation layers, and it seems it's only possible to disable or enable a layer.
When I animate the layer weight of my second layer nothing happens. I set it to "1" on the first frame, and to "0" on frame 25, but only the value of the first keyframe seems to be accepted.
Is there some secret trickery involved to make this work ? Because when I check the manual this should work.
Thanks.
Thanks.
- tamte
- 8833 posts
- coccarolla
- 78 posts
toonafish
Same here.
Thanks.
This is still happening in 20.5, I've just tried it on my scene.
