Instancing RBD sim
   1796   0   0
Hi! I'm trying to use octane to render a RBD sim.Since Octane doesn't support packed prims, I'm trying to use the instance node to use the points from the sim and the transform attributes to “transfer/instance” the geo to the points. It only seams to work correctly with instancefile attribute (which I know isn't currently supported in octane) but not the instance attribute (which is supported in octane). I've uploaded the project folder to dropbox, if you can take a look at it, I'd greatly appreciate it! Thanks!
https://www.dropbox.com/sh/rgpqoc6o32bpjla/AAAtS0Aa33CR6_GCWbH6QCKQa?dl=0 [www.dropbox.com]
