I am developing a tool that dynamically creates paint groups inside an asset. Everything was working fine, until I locked the asset and got this error:
PermissionError: Cannot create a node inside a locked asset
Is there any parameter on the Operator Type Properties window that I should be aware of?
Any ideas?
Dynamically create nodes in a locked asset
1340 1 0-
- cmchaib
- 1 posts
- goldfarb
- 3459 posts
not knowing your exact setup…
if you have an Object node that contains the SOP network where you are creating these groups you can set this node to be Editable
see > link [www.sidefx.com]
