I usually model in c4d,then import them into houdini to layout the scene,do lighting,shading and simulations.The problem is if the models are complicated(eg.CAD models),it’s so tedious and time-consuming to import them into houdini,and re-split,re-assign material to different parts,re-adjust the pivot…
It’s just so easy in c4d to build a scene using imported models.But in houdini,it’s way more complicated.Maybe i’m doing wrong?what’s the best way to import models into houdini?
the best way to import complicated models into h?
5176 4 1- wanglifu
- 186 posts
- Midphase
- 833 posts
Honestly I just use the File node, and then sort things out manually as far as materials, etc.
>>Kays
- EricSheng
- 159 posts
- w_maro
- 86 posts
hi
look at this tutorial on youtube
Large FBX Scene Workflow - Houdini for Noobs 21
here is the direkt Link to the tools
https://axisfx.design/tools
- gmanyyz
- 44 posts
