Houdini Python Module Search Path
   Views 4089   Replies 1   Subscribers 0
Is there a way of identifying the location of a Module imported into Houdini?
I'm contributing my Python modules to my Houdini17.5/python2.7libs folder but have recently discovered Modules with similar names are being loaded before my current Houdini17.5/python2.7libs. I keep all of my old modules around in their relative “deprecated” folders; Houdini17.0/python2.7libs, Houdini16.5/python2.7libs, etc..
Before I cry out “Bug” I wanted to verify which Modules are being loaded before the ones in my current Houdini17.5/python2.7libs folder. Any help identifying the location of these modules is appreciated!
Cheers
Hi there,
If you know the name of the module, then you can find the path in the python interpreter
>> import hou
>> hou
<module 'hou' from 'C:\Program Files\hfs17.5.386\houdini\python2.7libs\hou.pyc'>
If you want to know the order in which python libraries are getting loaded, then you need to check the PYTHONPATH env variable or sys.path
-J
