Using point attributes in a DopNet...
   1617   0   0
Hi everyone,
I have a wall geometry that has been fractured and packed. Each points in the packed object is assigned a “decimation” value between 0 and 1. Lower values are at the bottom of the wall and higher at the top.
Now, I'm trying, in a DopNet, to make the pieces at the bottom of my wall gradually disapear. The upper pieces, not having any of the lower pieces support anymore, would fall by gravity before disapearing as well.
I want to use my “decimation” attribute to trigger when pieces will disapear.
1) How can I use a point attribute from a packed object in a DopNet?
2) How can I use the “delete” dop node to delete pieces of an RBD object. I can only seem to be able to delete the whole object at a given frame and not individual pieces.
Thx!
C
Edited by cs_pix - Nov. 6, 2019 18:42:13
2019-11-06 15_28_06-Window.png (109.2 KB)
