Ocean Foam Sop Camera Region Issue
   2946   4   0
I'm following a tutorial on Ocean FX. When I turn on the camera region type in the ocean foam sop, all of the particles disappear? I've got the near and far set to 1 and 1500. If I turn the z density falloff from 1 to anything less than 1 they come back? It also looks like the falloff is having the opposite effect. Particles near seem to be less than those further away?
thanks a lot
WhaleSim_001.hipnc (1.3 MB)
Just in case anyone has a similar issue. I resolved it in the end by right clicking on the ocean foam sop, and allow editing of contents. Then inside the node put a Clean sop under ‘clip at near’.
Josh Wibberley
sorry to necro this… but it's still a bug in 18.0.460
Thanks for the fix!
Also… A Z-falloff lower than 1 crashes the software.
Thanks for the fix!
