Arclen (Solved)
   2403   1   0
Hey,
just a quick one, how do you use the arclen expression for measuring perimeter of a curve?
arclen(surface_node, prim_num, ustart, ustop)
Cheers
(Solved)
@primd = `arclen(“/obj/curve_object1/curve1”, 0, 0, 1)`;
Edited by ludwigvon - Nov. 14, 2019 10:34:46
ludwigvon
Hey,
Cheers
(Solved)
Don't use hscript in a wrangle. Use arclen("/obj/curve_object1/curve1", 0, 0, 1)in a float parameter and reference the result:
f@perimeter = chf('arclen_parm');
Segregation allows the vex code to be cached and reused when the value changes.
