How to add a special VEX function into Compile Block?
   Views 1533   Replies 2   Subscribers 0
Today I use a vex function called primuvconvert [www.sidefx.com]
Unfortunately it only support filename (string type) as geometry input, and I find if write it in a wrangle, the wrangle node will be non-compilable, because Compile Block seems only recognize spare input (-1, -2, … as vex function geometry input).
Can anyone help me? Thanks!
Edited by zengchen - Nov. 17, 2019 11:13:10
example.hipnc (71.3 KB)
My Youtube Channel [www.youtube.com]
you can use “opinput:0” to access first input's geo using string, it doesn't seem to be working for spare inputs, but from VEX you can access geo of it's inputs directly within compiled network
FX Supervisor
Method Studios, NY
tamte
Thanks a lot, tamte.
It works to me
Edited by zengchen - Nov. 17, 2019 12:20:01
