Bad parent found. (parent is not a network)
2425
2
0
- art3mis
- 350 posts
So unclear whether this is a Houdini specific error or there is possibly something wrong with my Redshift materials.
But when I simply try and cook a ROP Geometry Output node in TOPs I get lots of the following errors
Similar to this error but I am not using HQUEUE or submitting to a farm
https://www.sidefx.com/forum/topic/69162/ [
www.sidefx.com]
Edited by art3mis - Nov. 19, 2019 13:59:20
Bad parent found.png (246.6 KB)
- jsmack
- 8039 posts
Looks like the environment in which hython is running is not configured correctly, as the errors are due to the missing redshift plugin.
- Flatland
- 44 posts
hi!
have you ever solved this issue? could you get it to ignore those errors and start your rop geometry output node task?
