No more atmosphere, how to screenspace?
   1625   2   2
I used to love using the Atmosphere/Fog Shader builder to do screen space shading stuff at render time.
Now that that is deprecated, how do I do this? The documentation is kind of unclear.
As mentioned by jsmack, you can use your fog shader without the atmosphere node, directly to mantra(with pbr engine), after adding the render property vm_pbrshader.
Hi Pietro,
Can you elaborate a little more on how to do that ? I don't understand what you mean by “adding the render property vm_pbrshader”.
Thanks.
