i'm just researching Houdini for the use in my office - Can assets (a fire for instance) be exported to 3dsmax and then re-materialed with V-Ray inside 3dsmax or would i need to buy a separate copy of it for use in Houdini?
Thanks in advance - I hope i was clear
Using V-Ray with Houdini & 3DSMax
6898 1 0- Ribano88
- 1 posts
- GoshoGenchev
- 4 posts
Hey, Ribano,
I work at Chaos as a QA for V-Ray Houdini.
There's a lengthy page in the V-Ray for 3ds Max documentation regarding this exact topic. Here's the link: https://docs.chaosgroup.com/display/VRAY4MAX/Houdini+to+3ds+Max+Open+VDB+workflow [docs.chaosgroup.com]
In short - yes, you can save the simulation to VDB, however keep in mind that V-Ray's volumetric shader currently does not support separate fields for fire color and fire intensity. You may not be able to achieve 100% parity between a Mantra render and V-Ray when rendering a simulation which consist of both fire and smoke.
Hope that helps.
Hope that helps.
