Error messages when loading Houdini 18.0.287
   4325   2   0
ERROR in search: Error parsing ‘/nodes/sop/labs–flowmap_obstacle-3.0’
Exception in thread Thread-2:
File “C:\PROGRA~1\SIDEEF~1\HOUDIN~1.287\python27\lib\threading.py”, line 801, in __bootstrap_inner
self.run()
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\houdinihelp\api.py”, line 549, in run
indexer.update_with(w, pages)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\bookish\search.py”, line 465, in update_with
writer, pages, update_paths, needs_delete=changed
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\bookish\search.py”, line 494, in index_paths_with
for doc in self.documents(pages, path):
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\bookish\search.py”, line 401, in documents
jsondata = pages.json(path, postprocess=False)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\bookish\wiki\wikipages.py”, line 611, in json
self._pre_pipeline.apply(jsondata, wcontext)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\bookish\wiki\pipeline.py”, line 116, in apply
v.apply(block, context)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\houdinihelp\hpages.py”, line 324, in apply
self.apply(subblock, context)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\houdinihelp\hpages.py”, line 311, in apply
block = self._parse_opdef(path, block)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\houdinihelp\hpages.py”, line 296, in _parse_opdef
nodetype, version)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\houdinihelp\api.py”, line 835, in components_to_path
parts = [“/nodes/”, table_to_dir, “/”]
KeyError: u'gamedev:op'
– 1 —————————————————————————
How can I fix the problem?
https://www.sidefx.com/forum/topic/15604/ [www.sidefx.com]
Chris McSpurren
Did you find a solution to this? I have the same error after installing sidefx labs.
Cheers, Lukas
Edited by _EL - Feb. 11, 2020 08:50:06
