Hair is Pointing Up During Simulation ?!
   1969   5   1
I've been working with Hair Character for a while now. I imported the character as bego file, then did the grouping the of skull cap for hair to groom.
Everything was ok, but when I start the simulation I ended up with the hair pointing up ?! I do not know why?!
When I import the character as an Agent from FBX. The simulation works perfectly!
I am attaching my hip file.
Edited by John31 - Dec. 4, 2019 19:18:54
up to the air.PNG (1.5 MB)
betahairtest.hiplc (8.9 MB)
Guys,
I am stuck at this and i really need help in here.
Looks like something is wrong with Skin Collisions. If you untick that, the hair falls down like it should.
I think there is something wrong with the mesh, but I will investigate further.
Werner Ziemerink
Head of 3D
www.luma.co.za
Werner Ziemerink
Thx man! I will be waiting for ur feedback
Here is a fix for your hip.
I deleted everything except for the body. Have a look under the geo node.
betahairtest_fix.hipnc (9.2 MB)
Werner Ziemerink
Head of 3D
www.luma.co.za
That's awesome man! Thank you. I am not sure that there's an issue with the geo I imported maybe because something has to do with vellum cloth which I finished first.
Anyway, to get things together after simulation, I am planning to merge the blasted items, body and simulated hair together in one geo. I am open for suggestion is this regard.
Thank you again for your help appreciate your support
