Fog rays in houdini18
   3459   4   0
as a newbie I`m struggling with some light setups. How do you can make fog rays in houdini18? Found some tips about a atmosphere node and the litfog shader, but the atmosphere node is noted as deprecated and I have no idea to set this shader up. Any help is welcome.
Tia,
Jochen
Here you go.
Box with uniformvolume shader and a light with projection map.
Just hit render.
Edited by Werner Ziemerink - Dec. 17, 2019 13:23:35
Vol_Light.hipnc (653.7 KB)
Werner Ziemerink
Head of 3D
www.luma.co.za
Thank´s Werner,
it´s a start for me, you build your own uniformvolume shader, right?
No, you can crab it from the Material Palette and just assign it to any geometry.
https://www.sidefx.com/docs/houdini/gallery/shop/vopmaterial/uniformvolume.html [www.sidefx.com]
Edited by Werner Ziemerink - Dec. 18, 2019 04:34:42
Werner Ziemerink
Head of 3D
www.luma.co.za
that´s great
Thank you
