Vellum Cloth Solver: DOP Network Constraints - Solved
   1850   3   2
I am still experimenting with Vellum cloth using Dop network. But I cant figure a way to set Attach to Geometry node in the network.
Would anyone advise about this ?
Edited by John31 - Dec. 23, 2019 08:56:46
I am attaching hip file showing dop network. appreciate if someone can point me on how to constraint the skirt to the body geo in this order.
Dummy.hiplc (11.0 MB)
it's simply the same node that in Sop
you just have to point to the body path and group
i created a node to be sure i targeted the group you created
Ben
Edited by Benjamin Lemoine - Dec. 23, 2019 08:06:28
Dummy.hiplc (11.9 MB)
I got it now. I used to connect the node without filling the target fields, which eventually did not have info to tell the node how to act with the constraint. Unlike sop level node the node in dop level has one input.
Thanks for the help.
